MG HS – Continuous beeping when reverse gear is engaged, regardless of surroundings
Technische Hilfe für MG3, MG4, MG5, ZS EV, HS, Marvel, Cyberster und weitere Modelle seit 2005
mkukulka
Fahrzeug(e): MG EHS
Beitrag von mkukulka » 8. Jul 2025, 18:22
Hi everyone,
I have an MG HS and recently started having an odd issue. Every time I shift into reverse, there's a constant beeping sound. It’s not the usual parking sensor beeping – this is a steady, uninterrupted tone that starts as soon as I engage reverse and stays on the whole time, no matter what's behind the car.
My seatbelt is fastened, all doors are properly closed, and the reverse camera and parking sensors seem to work. But the beeping makes reversing really annoying and feels like something's wrong.
I've attached a video to show what's happening --> https://share.icloud.com/photos/0ccQUOi ... eFSHKh2dpQ
Has anyone experienced this or knows what could be causing it? Any advice would be much appreciated!
Xpower
Site Admin
Re: MG HS – Continuous beeping when reverse gear is engaged, regardless of surroundings
Beitrag von Xpower » 8. Jul 2025, 21:48
Hello stranger
A continuous tone from PDC sensors usually indicates a fault with one of the sensors.
Best regards, Peter
DonCarlos
Fahrzeug(e): MG HS PHEV 2025
Beitrag von DonCarlos » 11. Jul 2025, 22:29
Hello stranger,
the video shows the rear seat occupancy indicator.
The owner's manual states: If this light is lit or flashing, it indicates that the seatbelt for an occupied seat is not fastened.
This may also be accompanied by an audio signal. Try removing everything from the back seat or fastening all seatbelts.
Maybe that's enough.
Let us know what helped!
Best regards, Carsten
